Got 4.11's put in, now speedo doesnt work right
Well, got my 4.11's put in today and the difference over the stock (2.73's???) is insane. The car literally jumps out of first and can easily burn-out in second. I love it except the speedometer now reads like 80mph while I'm going much slower. I imagine that there was some kind of mechanism in the old gears that is now changed with the 4.11's that is screwing up the speedo. Any suggestions?
RE: Got 4.11's put in, now speedo doesnt work right
Yea you need to change the speedo gear and probably the gear inside the tailshaft. Do a search and you'll find plenty of threads with the right ratios you'll need [8D]
you definitly need a new drive and driven gear, you can get them on 50resto.com
check out this link for more info
https://mustangforums.com/m_1322654/tm.htm
you need a 6 tooth drive gear and a 20 tooth driven gear to get your speedo accurate. DO NOT... and i repeat DO NOT install the 23 tooth white gear, your speedo will still be off by 6-9 mph
