Frame Connectors
RE: Frame Connectors
Huum, I would not be racing or anything, this is a just a daily driver. It they came loose jsut tighten them back up! he he he.
Joking aside I see your point but under normal driving I see how bolt ons could work also I would think.
just get them welded for $100 at a muffler shop, the bolt on ones loosen from typical road vibrations and elongate the holes that the bolts go through, the welded ones are permanent and will not loosen, they actually fuse to the frame rails rather thanhold on tothem. jmo, do it once, do it right!
I have a WIFE, ha ha ha. Money spent on wheels has to be run past here. If I can show I can save some $$ I can get more done sooner, ha ha ha. I see your points on the welded setup. I will prob run with that but get bolt ons first or find a FRIEND to weld them.
I hear ya... you may want to invest in some pants while your at it, apparently your wife wears them. LOL I'm just kidding,[8D], I have one too, but shes all for the stang, sooner its finished we can start her project car. Best of Luck to you.Where do you live, we can weld them in for ya.
Ha ha ha ha. Well I also have a 1965 Tbird conv (www.yesfans.com/tbird/tbird.htm)that I am restoring so the funds have to go a long ways. I pick and choose my battles with her when it comes to $$$, ha ha ha ha.
Im just guessing but it would make more sense that it would have to be on the wheels.
ORIGINAL: deanzawistowski
when welding on subframe connectors does your car have to be sitting on the wheels how it normally does when its on the road?
can you just jack it up and weld them on?
