problem solved!
Old Dec 28, 2006 | 07:28 PM
notchback50's Avatar
notchback50
Default RE: problem solved!
how hard was it to replace the balncer??? becuz i get severe shaking when i floor my car, i thought it was my driveshaft but thats fine.
Old Dec 28, 2006 | 07:34 PM
mattdel's Avatar
mattdel
its not too bad, you need a 7/16" wrench to take the fan out, 7/16" again to remove the shroud, 15/16" socket preferably on an impact gun to remove the big bolt in the center of the balancer, and an 8mm allen wrench(hex key) to remove the crank pulley. also you need a balancer puller, can be bought at autozone. i did the whole thing in less than an hour, but i'm a tech.... so yah... lol
Old Dec 28, 2006 | 07:38 PM
Twisted's Avatar
Twisted
I'm no tech, but I did the whole thing in just over an hour. It's not hard at all. So Mattdel, are you gonna tell me about thepintle shaving?
Old Dec 28, 2006 | 07:40 PM
mattdel's Avatar
mattdel
ORIGINAL: Twisted
Glad you got all your issues worked out. I've never heard of the pintle shaving thing. Please tell me more about it.
i scanned for codes, and received an EVP(egr valve position sensor) code, i forget which one, but it was saying that it was open when it should be closed. carbon buildup inside the EGR will cause the pintle on the sensor to get pushed in, sensing EGR movement, when actually there isn't. i took it out(3 nuts, 11/32's) unplugged the wiring, grabbed the pintle lightly with vice grips so it wouldn't move, and walked over to the bench grinder, and just barely took a little bit off. i also ran the edges off, so it wouldn't be sharp.
Thus, allowing the pintle to fully extend without blockage. Cheap way of getting around replacing the EGR.
notchback50
i have a bad idle also and i have checked and cleaned everything, putting a new balancer corrected your bad idle? and how exactly do you do the balancer?
Old Dec 28, 2006 | 07:42 PM
mattdel's Avatar
mattdel
ORIGINAL: notchback50
no.. the EVP solved the idle, the balancer took care of the shaking, and hard shifts.
Old Dec 28, 2006 | 08:28 PM
notchback50
what exactly is the pintle?
Old Dec 28, 2006 | 08:31 PM
mattdel's Avatar
mattdel
its a small round piece of steel, about an inch long. about the same width as a small drill bit. it pushes in and out of the egr valve position sensor. the egr valve movement pushes on the pintle.
Old Dec 28, 2006 | 09:42 PM
notchback50
ok i remember the pintle now when i cleaned my egr it tryed cleaning it with it inside but there was still crap on it. so i can take it out and clean it up? the blancer sounds pretty easy. easier cuz i have an elctric fan and no shroud.
Old Dec 29, 2006 | 05:09 PM
Twisted's Avatar
Twisted
ORIGINAL: mattdel
ORIGINAL: Twisted
Ah, now I understand. Thanks for the explanation.
