What suspension is everyone running
RE: What suspension is everyone running
All that I've got at the moment is the Ford Racing C Springs and the Summit Racing upper and lower rear control arms (black) with the stage 8 bolts. I'm going to get after my suspension again after I order my shifter, valve body, wheels and tires.
D&D K-Member
D&D Coilovers (150lbs spring rate)
D&D tublar a-arms
Lakewood traction bars
BBK heavy duty upper control arms
BBK subframe connectors
BBK lowering springs
BBK caster camber plates
solid motor mounts and tranny mount
battery relocated to trunk
lakewood 90/10's
lakewood 50/50's
removed front sway bar
D&D tublar a-arms
lakewood 90/10's
lakewood 50/50's
I'm real happy with my set-up and it was quite inexpensive. On the track is handles great. I threw the MAC Performance catelog at my 92 notch plusa few other parts:
- Mac upper & lower rear control arms
- Mac progressive rate springs
- Mac camber/caster plates
- Mac strut tower brace
- Mac g-load brace
- Mac offset rack bushings
- Energy Suspension poly bushings, end links & isolators
- Eibach anti-roll bars front & back
- KYB Gas-a-just shocks & struts
- DaSilva Racing custom full length sub frame connectors
- MM Panhard bar is on my wishlist
This is not as high quality (IMO) as MM stuff but it was less expensive. It works well for my daily driver that sees some open track time.
- Mac g-load brace
ORIGINAL: 92hatchLX
No the stage 8 bolts give 23.3445 more horsepower, kinda like the difference between a srt-4 stage 1 and stage 45, big difference.
Yeah I meant grade 8
Now you know. And knowing is 1/2 the battle.....Ah, forget it.
stage8headerbolts , true but they aren't used for control arms . It's all good.
