deleting a/c and smog safe???
is it safe to delete both the a/c and bypass the smog???i saw a pic and someone said something that the belt could rub and could snap the belt...is this true??? also i wanted to know if there is any difference when u bypass the smog w/ a smaller belt or buy a delete kit and keep the same belt?
RE: deleting a/c and smog safe???
there is the possibility of belt rubbing together underneath the tensioner pulley when you do this, but if you remove the tensioner completely, and purchase the manual tensioner assembly from ebay, you get a nice new shiny part for under-hood, and stop the rubbing
personally i think the best way to do it is to get an alternator bracket with adjusting rod from march, they're like 60$. then you can dump the AC, the smog pump, and the bulky bracket with the tensioner. this way the belt will never rub, it will look cleaner and remove alot of unecessary weight.
ORIGINAL: HC_CrAzYHoRsE
ORIGINAL: Ninety5five0
Is this a bracet just for the alt. ? So you dont have the huge empty bracket hangin down ? If so, i'd be very interested. Got any links ?
http://www.marchperf.com/pg30.html
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
