Help with pulley noise
I have a squeaking noise comming from one of my pulleys. It sounds like its comming from the smog pump or alt. I put belt dressing on so its not the belt. Can i spray in there with some WD40 or something or is that bad? Its not all the time either, its like squeek.........pause..........squeek.........pause ...........squeek like that
Dude you need to get layed or something, every post i see you Wight is negitive or you have to bash.....Dont be a faget!!!! Is it ok to lube them up or what? I dont want to take the belt off
ORIGINAL: tom50
If that doesn't help then remove the belt and check the smog pump and alternator. Bearing could be going bad.
the smog pump is notorious for seizing up, but the alt will sound squeaky too if it's going bad.
is it charging ok ?
if the smog locks up you can bypass it for a while w/ a gates # KO60705 belt
that will pass the PS too though, but you can get to where your going.
if you have ud pullies you need KO60695
is it charging ok ?
i used a garden hose to find out what pully was squeaking one time....real slow flow and gently wet the hub of each pully until noise stops. Then you know what device you will be replacing.
Might not be able to tell by taking belt of as you will never spin the pully as fast as a running engine.
