a/c compressor troubles
RE: a/c compressor troubles
Good advice if that happened. It wouldn't entirely surprise me if a blown compressor is the culprit.
I have been through that on a previous car. Replaced the entire friggin a/c system, and the car got totalled by a drunk while it was parked in front of my house.
ya that dood's in jail for that still. cops through the book at him. He hit 5 other cars on my street before my bonneville stopped him.. ha ha jerk
noooo do not remove the compressor, if you release the refrigerants you can get fined VERY HEAVILY, dont take matters into your own hands with something of this nature you need an EPA lisence to work with it, take it toa shop(i have a refrigerant lisence so i know about this stuff)
there are most likely no o-rings on there, its aluminum tubing and if you heard a hissing than your r-12 most likely leaked out and your system was run dry thus causing the compressor to burn up...and that could make it stop spinning, thus making the clutch shatter......
Guys any help here is MUCH appreciated here and I am open to other suggestions. I need to head to bed (midnight here). If you look at Iceman's pic of his engine compartment you can more easily visualize what happened. In the very front and center of the a/c clutch you will see a circle that sticks out in front of the a/c clutch. the filler area inside of that circle is where everything melted/blew out/ disintegrated. The pulley isn't going to turn very well.
I'm trying to keep the cost down as much as possible. I don't have a whole lot to spare right now.
Thanks a ton!
Thanks a ton!
