Engine Temperature?
Old Jan 2, 2007 | 03:54 PM
90Lxstanger's Avatar
90Lxstanger
Default Engine Temperature?
I was just wondering if anyone else's engine takes a while to warm up b/c mine sure does. Ususally takes about 10 miles and it might be warmed up to 190, which id say the thermostat is. Thanks for the help
Old Jan 2, 2007 | 03:56 PM
stangcrazy's Avatar
stangcrazy
Default RE: Engine Temperature?
As long as its not running hotI wouldn't really worry. If I recall correctly most of my cars do the same.
Old Jan 2, 2007 | 03:58 PM
pizzarolls's Avatar
pizzarolls
mine certainly does.....i have the opening in the hood though. is yours cut out or no?
white91fox's Avatar
white91fox
my 91 takes a good bit to warm up. but its just like a old ford truck. if you live in a cold area you could block off half of the rad to heat it up faster
Old Jan 2, 2007 | 04:26 PM
88BlueGT's Avatar
88BlueGT
My 93 takes a while to get up to temp, I dont know about 10 miles of driving though. I usually let it run for 5 minutes before I go and usually the needle is just starting to move. I just go easy on it until I get up to normal temp which takes about 5 mintues of driving.
Old Jan 2, 2007 | 06:47 PM
notch5oh's Avatar
notch5oh
thermostat could be stuck open too
but i think its just that the temp guages on those old engines arent very accurate
Old Jan 2, 2007 | 10:36 PM
90Lxstanger
I think the thermostat is fine, I have and aftermarket temp gauge, the hood openeing are cut out. I try to start my car be4fore i leave usually, maybe i should let it warm up a lil more though, ist nothing bad tho, i did read something on fordfuelinjection.com that said your car isnt properly warmed up until 185 degrees, and thermostats lower than that can hurt your engine.
Old Jan 2, 2007 | 11:53 PM
ballzoutstang875.0's Avatar
ballzoutstang875.0
you're thermostat is fine! I've had 5 fox body 5.0's and it took all of them about 10-15 mins.to warm up.
it's a good sign because if no thermostat... overheat! older cars need some time to get movin inthe morning's...
Old Jan 3, 2007 | 12:01 AM
89stanglx's Avatar
89stanglx
Ican make it to work about a 10 min drive without my electric fan turning on this time of year.
Old Jan 3, 2007 | 01:30 AM
g2_5point0's Avatar
g2_5point0
ORIGINAL: ballzoutstang875.0
if there's NO thermostat, the car will over heat? explain to me how this happens, because i run without one
