heater
RE: heater
No heater control valve on the fox. If the engine is running, coolant should be flowing through the core regardless if the t-stat is open or closed. If the hoses are attached and the vents blow no heat - you have a blend door issue or the core is plugged up. Check the temp of the hoses. If the inlet is hot and the outlet is cold - it's plugged. Otherwise if they are both hot - it's the blend door.
Seanam
10-04-2015 10:15 AM
Calizic
08-28-2015 01:46 PM
