Compression ratios questions
Just to clarify that although Adder is once again being attentive and helpful, his reply is an estimate. Specific measurements like combustion chamber \ piston volume with the gasket anddeckheight are needed as well as standard ones like bore and stroke. Hell, I could be wrong. Maybe Adder knows a 5.0 that well.......
whoops... scratch that... my reasoning was wrong.... its .005 comes out to roughly 1cc taken off the heads combustion chamber
however, it still shoudl give him a ~58cc chamber which is ~9.5:1 compressionr atio
So the stock head is 64cc's? I thought I read that a stock E7TE is 61.5..correct me if I am wrong.
Also, is the .005 to 1cc common on all heads or just these ones specific?
ORIGINAL: shaners90lxhatch
ORIGINAL: 5.0stanger
https://mustangforums.com/fb.asp?m=2181932
https://mustangforums.com/m_2182040/tm.htm
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
treesloth
Sep 28, 2015 07:03 AM
