Cam Questions
Cam Questions
Okay i just found out my moms friend has a cam he will give or sell to me. Im not sure of the specifics yet but i will post them tomorrow when i find out. My question is will upgrading to 1.7 rockers be as beneficial as a new cam? I know it depends on the cam specs but i just want to know in general. Also, if you install a new cam, do you have to get a new computer, or can you just reset the stock computer?
RE: Cam Questions
It's always good to get a tune when you change your a/f ratio....
Also, a cam in a stock motor won't be HUGE, but if you combine it with 1.7 rocker rollers, you will feel the difference.
Cam lets more air in, 1.7 rockers use it.
RE: Cam Questions
Yes, the e303 cam is a good "street legal" cam, meaning that it will not cause you to fail the emissions. the specs on the E303 are: Duration: 220°/220° @ .050' Lift: .498'/.498' and it retails for $165
RE: Cam Questions
k cool. ive been searching around and havent really seen any negatives about the e cam. Im definately gonna get it because the guy is selling it to me for $20 and hes going to help me install it because ive never done it before.
RE: Cam Questions
considering the stock lift is only .442", the .498" lift combined with the 1.7 rockers should make a noticable difference. just make sure to check the piston to valve clearance so you don't run into a problem. if in doubt, use the 1.6 rockers and you should be OK.
