hoist the engine
RE: hoist the engine
check this out. 2 head bolts.
http://s145.photobucket.com/albums/r210/fox302/
not sure which pic will give you the right idea but you can go from there.
the trick is...you want to get the chain atached as close to the block as possible...you do not want to leverage a long bolt and break it..if the bolt is too long use washers between the bolt head and the chain to force the chain closer to the block.
not as much of a problem if you strip the heads, and intake, accesories while the engine is in the car..I tend to pull the engine and tranny as one unit..
one of my recent pulls...be warned...its not a ford....
http://i128.photobucket.com/albums/p...3/100_4737.jpg
i wasnt pulling the engine i just bought a 351 and had it on the ground and need to put it in a truck and move it to my brothers house. i got it done i just used the factory lift thing on the block and a strap around it
AmericanMuscle4.6GT
11-10-2015 02:06 PM
TfcCDR
09-14-2015 12:08 PM
