T-5 Removal
RE: T-5 Removal
ORIGINAL: dimebag
im doin it next weekend i think, i can tell ya how i did it then if u can wait that long.
my plan is to unbolt the mid pipe, drive shaft, and tranny cross member, unbolt the trans, slide it back, and drop her out, and then put the new(rebuilt) one in. should work that way, i can let ya no if anything ****ed up so u can no to look out for that
RE: T-5 Removal
ORIGINAL: Arno
No.....the trans wont come off of the BH? It appears as though only 4 bolts hold it in place. Even if I did remove the BH, it would seem to be easier with the trans out of the way.
ORIGINAL: SSKiller
No....take the bell housing off with the tranny. You will not disturb the clutch because the pressure plate is bolted to the the fly wheel enclosing the clutch.. While you have it off, you can check the conditionof the pressureplate, and clutch. Better to look now and see if you have to replace something then later and do it all over again. Alsothink about getting a new throw out bearing also.
RE: T-5 Removal
I agree w/ SSkiller/Adder. I've always removed the tranny w/ the bellhousing attached (i.e. remove it at the block). It's not that difficult if you have 2 people or if you have a floor jack to stick under it.
RE: T-5 Removal
ORIGINAL: gspfunk
they are 15mm btw
RE: T-5 Removal
ORIGINAL: AdderMk2
whoa now... i never said he should remove the bell housing with the tranny.. infact, I think its more work than you need to put into it... 4 bolts hold the tranny to the bell housing... just unscrew them and the transmission slides right out... this isnt exactly rocket science...
they are 15mm btw
ORIGINAL: gspfunk
they are 15mm btw
I hate to actually agree with Adder, but that was all I was asking, Can it be done....
RE: T-5 Removal
well in dimes case he's gunna have to wiggle the tranny around a lil to get the splines to line up... you proly will to even if things aren't moved... and make sure it's in neutral when putting it in
RE: T-5 Removal
i figure itll be easy enough... next weekened i guess[:@] wanted to do it this weekend, but as ya no 94gt, i kinda ran into a few bumps in the road. but should have the heads back from our guy sometime this week, one of my heads is done, so hes gonna make some calls and try to get me one for a good price, if not im gonna pull one off of a 95 at a junk yard. hes gonna check them both for warpage of any kind(which i could do, but he has them), and if there warped at all hell have them fixed, and hes going to do all the valve seals, etc for me too... and the best part... for free. just gotta wait to get it all back, hopefully then thatll be done next sat and the trans can be next sun. hell i wanna get that trans done, the sooner i do that, the sooner i get my core charge back, lol.
