Priming though distributor
I'm trying to prime my rebuilt 331, i would like to know the method through the distributor and a drill. Can someone run me through this and please give as many details as possible i would appreciate that, i have never done this before. thnx
RE: Priming though distributor
If u have an extra distributor you could take the gear on it off put it in like you would normalytighten it down and just hook up the drill where the rotor goes on and spin it counter clockwise for like 20 or 30 seconds. If your not worried about messing it up you could just take the gear off the one your using and then put it back on
First u will need a 1/4 inch socket and a LONG extension. Use a small piece of tape to secure the socket to the extension so the socket doesn't get stuck on the oil pump drive shaft. Make sure u turn it counter clockwise. Good Luck.
I wouldnt do it that way. there is a chance that you could drop somthing into the motor. and it wont spin it fast enough. The only thing you have to do to get the gear off the distributor is pull out one pin. thats it. But its your car so that makes it your choice. just tryin to help.
