turn signal dont work
ok changed all the flashers, checked the ignition switch.. changed the signal thing. the hazards work like they should. i push the button they come on. just when i flip the switch for the turn signals i get nothing. i was looking and maybe it is the orange and yellow wire on the turnsignal connector. that is for the turn signal so maybe it isnt al the way in or it is cut somewhere or sonthing. anything else would greatly appreciate it. thanks!
Hve you had your dash out recently? I had the same problem...read this https://mustangforums.com/m_1467079/tm.htm
bet you its the wiring to the switch...if u mess up one wire it wont work....i completly screwed mine up but i was able to fix it without a diagram....there are like 6 or 8 wires or something right....make sure you have the all the switches in like the fog lights...defroster..head lights too b/c the wiring is linked. ask me if you need a diagram to see if the wires are in correctly
well i havent checked any of the wires yet but i will do that tommorow. it looks like all the wires are plugged in and none are loose. i will cehck it out. i dont understand the diagram very well. but if the wipers work doesnt that mean the power is going to the signal? or does the turn signal and the windsheild wipers have different power voltages? if so then that might make things a litter easier.
