P/S cr@pped out
RE: P/S cr@pped out
[align=left]Looking at that picture, when the piston moves to the left, the fluid would come out of the left eqaully as the rightside would suck it in,it would be a equal amount of fliud transfer...I don't understand why it wouldn't work.[/align]
RE: P/S cr@pped out
There would not be suction issues. There would be equal transfer of fluids, unless you didn't have it full(then there would be suction issues) You are going to have pressure pushing fliud into the side sucking, and if your worried, use a peice of metal tube.....Who cares. I think it will work
RE: P/S cr@pped out
There is a guy on here runing a 408 with the stock rack and no pump going to it. Ill try to find his name so you can ask him
edit: I think his name is randy***** the stars are some numbers. His zip i believe
RE: P/S cr@pped out
i found the problem. the hose had some cracks on top of it causing the fluid leakage. my dad put some rubber cement type thing on it and wrapped it in some weird tape. its holding up for now until i can get some cash to replace the hose.
