Long Tubes vs Shorties
#21
![Default](https://mustangforums.com/forum/images/icons/icon1.gif)
ORIGINAL: ckyguy68
Well, im building a 393 and im probably going to get the long tubes. I dont even know if they make shorty headers for the 351w.
Yes, get long tubes, my shorties choked off my power band at 5,200rpm, first thing I'm going
to do is upgrade to LT's and an Anderson 4" inlet Power-Pipe.
#22
unless you going to run a turbo system then i would go withLT's if you building a well built motor then its worth the time and money to go LT's,I have a set and im happy. And as far as for a auto cars thats what my car is and i haven't had any probs at all not even with the install .
Might as well spend the money and do it right the 1st time !!
#23
Blue.... I agree on the dyno facts but
I told ya so... they're going to debate this and give thier opinions regardless of the factual dyno numbers. *shaking head side to side*
#24
Wow, ya'll be gettin specific in here. As they said, LT flow more, shorty's look better from the outside and don't hang as low as LT. I think, not sure, I think that shorty's can be mounted to your factory exhaust. Don't quote me on that.
#25
ORIGINAL: aftlcc
![Big Grin](https://mustangforums.com/forum/images/smilies/biggrin.gif)
As far as power, LT's will provide better power than shorties on any motor. The gains might not be as much on a mostly stock 302 as compared to the gains from a H/C/I 302 or a larger CID motor, but they will still provide better flow/scavenging.
As for shorties not being any good...compare any set of stock headers to adecent brand shorty (BBK, FRPP, etc). Even there you can tell the difference in the diameter of the primaries and the bend/dents in them....better quality too....and yes, aftermarket shorties will bolt up to the stock H.
<==running FRPP shorties on stock H (until I put my Prochamber on this weekend!!)
#26
ORIGINAL: aftlcc
#27
+1 with LT's over shorties. Now there is a difference; Is the extra horsepower worth it to YOU. The facts are there, and proven. And the install is not hard, lift the front of the engine and slide them in. Big woop, if your worried about the install, then your really not worried about the extra power. So the question comes down to; If your willing to do some extra work...
Oh, and they do hang a little low...
#28
I don't have an answer, but here's a link to a nice article on the air-flow principles of headers based on pipe length and diameter.
http://www.carcraft.com/techarticles/header_basics/
#30
I figured I would add that so somebody who KNEW would be able to say weather it would work or not. My bad for tryin to help someone out. What is makes it different having an automatic than a 5 Speed?
