bad feel bad sound part 2
RE: one problem fixed new problem started
That is the same kit I have...I like it
He most likeky didn't hurt your tranny. With all the clutch swaps I've done, I have never had trouble shifting afterward...I don't beleive that is considered normal. Adjustment is out of wack IMO
o ok lol put it this way if a girl tried to drive mycar right now she wouldnt be able to drive it unless she took of in 3rd cuz she aint gettin it in first or second unless shes on roids thats about the best way i can put it, so i guess im just gona go ahead and order my exhaust system and that kit tonight
so i should be alright?
DOESNT MAKE SENCE TO ME shifting into gear from a dead stop clutch related wouldnt it be tranny related or something even tho it was fine before i took it in to the shop
OMG! I can't take it. Your clutch is out of adjustment, if you have the factory pawl and quadrant there is trick to setting it the way you like . The book tells you to lift up on the pedal and you will hear a click, but I never liked the way it would self adjust so I learned this trick. You have to know what your feeling for and what to push but it can be done. Better yet, just go get an adjustable unit and be done with it.
yea sounds good im just gonna have to set it but now im back to this again i take back my first sentance now that i drive the car more i still hear the sound from my original post before i replaced the clutch the rubbing/grinding sound coming from the drivline somehow thought it was the clutch but i guess not https://mustangforums.com/m_2471780/tm.htm
The reason it's hard to get into gear is clutch misalingment. It's not disengaging all the way when you press the pedal, so you're having to fight it to get it in gear. It's possible that you have tranny issues, but not as likely.
I went w/ the Steeda quadrant kit and like it.
