HELP
Old Jan 12, 2007 | 02:08 AM
BackInBlack90LX's Avatar
BackInBlack90LX
Default HELP
is there anyone in this forum i can call on my cell phone for some help on my problems because i think i have a hard time describing it on here because i can different answers from everyone
someone with some knowledge please reply
Old Jan 12, 2007 | 02:11 AM
Stevens91gt's Avatar
Stevens91gt
Default RE: HELP
post your problem so people have a general idea
and then you may get someone who's had the same problem
and then have them call you or something
Old Jan 12, 2007 | 02:13 AM
BackInBlack90LX
Default RE: HELP
ive made two different subject topics that pretty much sum the whole thing up
before i replaced the clutch and after
https://mustangforums.com/m_2471780/tm.htm this was before i replaced the clutch and im still having the same problem just not as bad
Old Jan 12, 2007 | 02:14 AM
Stevens91gt
Default RE: HELP
ahh my bad..didnt see the posts
Old Jan 12, 2007 | 02:16 AM
GaryBisiniere's Avatar
GaryBisiniere
Default RE: HELP
kinda had the same problem. are you feeling like a reeallhard vibration?
Old Jan 12, 2007 | 02:19 AM
BackInBlack90LX
Default RE: HELP
only from take off in first and reverse and its like a rubbing sound but once the clutch is released and im driving its fine threw all the gears
so it only last for like 2 seconds and it stil does it after i replaced the clutch!!!!!!!!!!
Old Jan 12, 2007 | 02:20 AM
GaryBisiniere
Default RE: HELP
kinda sounds like my problem except it did it in every gear after a certain rpm. chances are when you replaced the clutch you ruined the pilot bearing. id try dropping the tranny and replacing the pilot bearing.
Old Jan 12, 2007 | 02:26 AM
BackInBlack90LX
Default RE: HELP
so since a shop installed it the labor should be under shop warranty since i got it installed today right
Old Jan 12, 2007 | 02:29 AM
GaryBisiniere
Default RE: HELP
uh ohhhhhhh no idea about that i do all my own work. it sucks i dropped the tranny 3 times trying to figure out the problem. first i had a clunk when i pushed in the clutch. fixed that then i had vibration. dropped it checked the clutch put it back still did it. finally thought about the pilot bearing dropped it again and sure enough that was it.
Old Jan 12, 2007 | 02:31 AM
BackInBlack90LX
Default RE: HELP
how do you think the pilot bearing got ruined
