E303 doesnt work with afr 165s??
RE: E303 doesnt work with afr 165s??
First off, your lift is .529.
Scenario 1: I hope you clayed it up b/c AFR's are "iffy" at that level of lift as far as piston to valve clearance is concerned. I ran my E cam w/ 1.72's, but it was on ported E7's w/ stock valves. I would remove the rockers and do a compression test as someone suggested. If you still don't have compression, you may have bent a valve [or several[]].
Scenario 2: Are you sure you tightened the rockers correctly? If you didn't, they could also be keeping the valves open, thus no compression.....
Other than that, double check your intake to make sure the lower is mated to the heads correctly and the U and L are mated correctly (i.e. flush, w/ no gaps or incorrect fitment).
Ahhhh, gotcha.
Is it a new motor? Just curious....
I could definitely be mistaken, but I don't think the cam being in wrong would cause 0 compression in all cylinders. The valves wouldn't open at the correct time, but they would still open and close......
ORIGINAL: seanjohncombs001
it creates vaccum instead of compression, the motor has like 100k on it.
very simple
did you install the camshaft dot at 6 o clock
and the crankshaft at 12 o clock, . with no compression, thats a serious issue that requires your attention
