could this setup make 500HP?
RE: could this setup make 500HP?
500hp?????? dont think so maybe at the cranck but thats it! Also on ur charger you said u run 8lbs 10lbs go in for a dyno run and change it to 12lbs and ull get that 500 but i wouldnt keep it that way untill atleast i got a after or inner cooler. Or keep it at 10lbs and give it a good 50shot and ull get those number!!
I'd say 450 rwhp, I'd look into a set of AFR Heads, but since you've already had everything port matched, your kinda set up for the irons [&:]. You'd have to do a full intake/heads combo swap, I also agree with bumping your boost to 12 psi, as long as boost timing is retarded and A/F is in check. A methanol injection kit, or cooler box, should add a few horse as well. A dyno will be the best way to find out, andyou should have it fully tuned anyhow,whatair/fuel monitoring system areyou using?
NO![quote]ORIGINAL: 500HPCobra
Long rod 306 w/Manly steel Rods and Pistons, Studded and girdled with all ARP hardware for ged pistons ..specs .30 over..1.38 comp height..91210 wrist pin..5.315 rod...3.00" Stroke..430 Grams
GT40 Iron heads fully polished and ported professionally (have before and after flow sheets) Also has ARP head studs
Vortech (Polished) V1 S trim supercharger with power pipe 8-10 psi
BBK throttle body 70mm
BBK Elbow
BBK Long Tube Headers
DynoMax Mufflers
83MM Pro-M MAF calibrated for a supercharger car with 36lb injectors
Edelbrock RPM intake manifold...Port matched for heads
36Lb fuel injectors, Aeromotive fuel rails, 255 intank and inline fuel pump..Fuel presure regulator
Built World Class T5 transmission with hardened input/output shafts..New Tremec gears
Spec Stage 3 clutch
Aluminum flywheel
Aluminum driveshaft
[/quote]
BBK Elbow
DynoMax Mufflers
Spec Stage 3 clutch
Aluminum flywheel
Aluminum driveshaft
[/quote]
Well I have not got it "dynod" because it's a guy who is selling his. I am about 85% sure I will buy his mustang. He said it dynod at 475AWHP so I was just checking to see what you all though.. It seems most say it's real close..
