could this setup make 500HP?
Long rod 306 w/Manly steel Rods and Pistons, Studded and girdled with all ARP hardware for ged pistons ..specs .30 over..1.38 comp height..91210 wrist pin..5.315 rod...3.00" Stroke..430 Grams
GT40 Iron heads fully polished and ported professionally (have before and after flow sheets) Also has ARP head studs
Vortech (Polished) V1 S trim supercharger with power pipe 8-10 psi
BBK throttle body 70mm
BBK Elbow
BBK Long Tube Headers
DynoMax Mufflers
83MM Pro-M MAF calibrated for a supercharger car with 36lb injectors
Edelbrock RPM intake manifold...Port matched for heads
36Lb fuel injectors, Aeromotive fuel rails, 255 intank and inline fuel pump..Fuel presure regulator
Built World Class T5 transmission with hardened input/output shafts..New Tremec gears
Spec Stage 3 clutch
Aluminum flywheel
Aluminum driveshaft
BBK Elbow
DynoMax Mufflers
Spec Stage 3 clutch
Aluminum flywheel
Aluminum driveshaft
RE: could this setup make 500HP?
ORIGINAL: madd_hatter_1979
if not then get the friggin laughing gas...or go turbos and turn the boost way up...
i bet the guy is already broke with the motor being finished......he is already going to be on the borderline of the bock
haha, no I wouldn't change my name. [:'(] This is not mine (yet) I am about 1 week from buying it. Just making sure because I don't know a lot about stang's. I mostly know 3000gt/stealth engines. Thanks for the help guys!!
