So.. my hood flew up :/
#23
RE: So.. my hood flew up :/
i dont feel so bad now . the first time it happened i washed my car and was going around the block to get some of the water off and gassed it in front of the neibors house it stuck up till i got home. the second time i was giving rides after the turbo install and checked my oil while i was talking then just got in and took off like a bat out of hell SLAMO !!!
#24
ORIGINAL: AdderMk2
one of these days you guys will smarten up and use hood pins
#26
the guy who owned my car before me had the hood fly up 6 times. 3 of the times in the same day, his dumbass just would put it back down but the latch didnt work right. so the cowl was all smashed up much worse than yours and the roof also has two big dents right above the windshield from when he had a fiberglass hood fly up which also broke the windshield.. the fiberglass one did the most damage. tomorrow ill be using fiberglasst and bondo to fill in the dents from the cowl so hopefully it turns out good.
#27
ORIGINAL: Edge_of_Sanity
pin latches suck cause anyone can open your hood.. the locking ones are better
#28
[blockquote]quote:
[/blockquote]
I never said that you should use ONLY hood pins... Ive got a set that are going on my car, but im keeping the stock latch as well
[/blockquote]
#29
i have had the same thing happen although not as deep of a dent. i can't fit a hammer or anything inside to bang out the dent and i have tried one of those stupid dent pullers with the glue on them and they are not strong enough to pull it.
so could someone please tell me a good method for pulling this out, it doesn't have to look pretty but just enough to get my wipers aligned with the window again.
