Need Some Build Advice......
RE: Need Some Build Advice......
CamStyle:
Hydraulic flat tappet
BasicOperatingRPMRange:
2,000-6,000 RPM
IntakeDurationat050inchLift:
230
ExhaustDurationat050inchLift:
230
230 int./230 exh.
AdvertisedIntakeDuration:
280
AdvertisedExhaustDuration:
280
AdvertisedDuration:
280 int./280 exh.
IntakeValveLiftwithFactoryRockerArmRatio:
0.512 in.
ExhaustValveLiftwithFactoryRockerArmRatio:
0.512 in.
0.512 int./0.512 exh. lift
LobeSeparation(degrees):
110
IntakeValveLash:
0.000 in.
ExhaustValveLash:
0.000 in.
GrindNumber:
FS 280H-10
ComputerControlledCompatible:
No
LiftersIncluded:
Yes
LifterStyle:
ValveSpringsIncluded:
No
RetainersIncluded:
No
LocksIncluded:
No
ValveStemSealsIncluded:
No
TimingChainandGearsIncluded:
No
AssemblyLubricantIncluded:
Yes
PushrodsIncluded:
No
RockerArmsIncluded:
No
GasketsIncluded:
No
Quantity:
Sold as a kit.
ORIGINAL: disturbed471985
Go with comp cams 280 H Magnum god those things sound beastly and ive seen them streeted
yes and no i didnt drive the car but just hearing it it didnt sound to bad u could tell it was cammed out the *** but i didnt think it was that loppy. But at about 2000 2500 that mf screamed!
CamStyle:
230 int./230 exh.
CamStyle:
230 int./230 exh.
If you plan to boost it, get something with higher exhaust lift and duration the the intake to help get the exhaust gases out.
Also, find one with a LSA around 112-114 degrees for goodidle (lopey, but stable).
TFS Stage 2 has 114^ LSA and holdsa very good idle. I think Crane makes a cam close the the stage 2 except with a little more lift on the exhaust.
I would look at the TFS Stage 1. The higher exhaust lift/duration is good for Ford iron heads. The Stage 2 would probably cause PTV issues w/ your stock bottom end and larger valves......
Nice to see you back on MF.com....I haven't seen you around in a while.
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
