BRAKE WOES!
BRAKE WOES!
So I was going to do my front brakes today and after getting the the driver side done i rounded off the bolts on the passenger side and now I am screwed! Does anyone know round bolt tricks? Also, I bought ceramic pads and new rotors. Now when I drive it makes a weird scuffing sound from the pad touching the rotor. Is this just because the pads need broke in still? HELP ME PLEASE!
RE: BRAKE WOES!
Did you clean / lube the sliders before you put the new pads on the one side. I've had good luck with Matco's bolt extractor set. As long as the head isnt totally mangled, it usually works like a charm
RE: BRAKE WOES!
Yeah I cleaned the rotors, I sprayed 'em with brake clean really good before I put them on. Clearences? What clearences? I never knew of a clearance on brakes. Maybe run out, but that wouldn't make this noise.
RE: BRAKE WOES!
Well I went and drove it around a bit more and the noise seems to be getting quieter and quieter, so I am thinking its just part of the break in period for ceramic pads. I have never used 'em before, guy at parts store told me they are the way to go if I dont want dust and I wanna stop hard sometimes. SN95's have sealed wheel bearings BTW. Thanks for you guys help, Ill let you know if it goes away totally.
