Where is Your MSD Box Mounted
I need to mount my MSD 6AL but here is the problem...
1. I dont want to put the battery in the back/hatch
2. The Methanol Injection is going where the intake used to be on the passenger side fender so it cant go there either
I tried mounting it under the battery on the frame rail, but it hits the shroud/overflow tank when that is put in...
RE: Where is Your MSD Box Mounted
through the car. the wires dont run all the way back to the battery. its kinda hard to explain how everything is wired up, mostly because i hate wiring. if you want i could take a pic for you next time im at my car.
I mounted mine where the original duraspark ignition module was mounted in front of the driver side strut tower.
-P.
PS: Mine the motorsport MSD version so my box is smaller and its a direct swap.
-P.
Why dont you want to mount your battery in the trunk?
1) It will look 10x's cleaner
2) Better weight distribution
3) It will free up room for your MSD Box.
Im not sure how everyone else ran theirs but my starter soleniod is inside my fender so I ran the cable from
Under the fender
Through a grommet hole inside the firewall around the door area
Through the door sill
Under the carpet
Around the rear seats
Around the back of the rear seats
Cut slice in carpet and pulled through battery box.
Under the fender
Under the carpet
