which is better 306, 331, 347
RE: which is better 306, 331, 347
I am looking to run low 11's on nitrous the car has Trick Flow Twisted Wedge Heads, N-91 cam, holley systemax intake, 30lb injectors and all the other small stuff, i am running a 125 shot. I have plans to use a sportsman block
I would just shoot for a 11 sec 347 NA than... and spray it when you want to and you can have a 10 sec car on spray. But I would run something different than those dinky TW's on a 347
The thing is though, if you builda NICE 347 stroker you wont need nitrous. You will max out the block NA. You will have to change your setup though and Im not sure if you plan on doing that or not.
ORIGINAL: xtremestang94gt
i going to be putting a new block in my car if any one has a perferred size what is it and please list strong and weak points of them
