dynamat hoodliner
RE: dynamat hoodliner
its already painted but it didnt cover up the fiber particles its some what smooth i guess but you can still see the texture of the hairs a buddy of mine gave me to ideas......some sort of fiberglass filler then sand to make a flat surface or just take some sand paper and try to gently sand it down to get it as smooth as possible......do you know if anyone makes a high temp spray glue?
i worried though its a working cowl and under the hood is not to smooth so im just worried that it after it sticks that a lil later down the road it will fall or start to look crappy
the hoodliner seems like more of a sticker also how will it add lbs its just foam? i believe a nitrous bottle, subs, other stuff will affect it greater than a 3'x4' or so piece of sticky foam
