turbo
Old Jan 21, 2007 | 10:08 PM
luckythirteen13's Avatar
luckythirteen13
Default RE: turbo
ORIGINAL: turbosha
2 wastegates, a blowoff/bypass valve. boost gauge,fuel press gauge, fuel press regulator with press. port, lots of tubing and patience its not a breeze.
intercooler, bigger injectors, bigger maf, oil lines, two o2 bungs, flanges, the ability to cut and weld tubing, a place to dyno tune it
Old Jan 21, 2007 | 10:14 PM
JeffUtica's Avatar
JeffUtica
Default RE: turbo
ORIGINAL: Cleeman99
whos got some pics of a turbo and just how do they work
Go here and scroll to the bottom. http://www.cardomain.com/ride/791057/10
There are (2) parts to a turbo. The turbine side and the compressor side. They both share a common shaft.Exhaust is what turns the turbine. A turbo uses exhaust flow to turn the turbines impeller/wheel and subsequantly turns the compressors impeller. The compressor sidetakes inair (like a superchager), compressing it, then passes it through an air-to-air intercoolerand forcing it into the intake.
A turbo uses uses exhaust to turn the turbo as opposed to a centrifigal or roots style supercharger that uses the crankshaft and belt to turn.
Old Jan 21, 2007 | 10:26 PM
Cleeman99's Avatar
Cleeman99
Default RE: turbo
thats it
Old Jan 21, 2007 | 11:04 PM
Cleeman99's Avatar
Cleeman99
Default RE: turbo
what would u guys think of this kit to start and will 5.0 headers work on my 351w http://cgi.ebay.com/ebaymotors/Musta...QQcmdZViewItem
Old Jan 22, 2007 | 12:42 AM
luckythirteen13
Default RE: turbo
dont buy an ebay turbo kit. they come with ****ty parts.
Old Jan 22, 2007 | 01:51 AM
Ryaannn's Avatar
Ryaannn
Default RE: turbo
In regards to the ebay turbo kit, I came across that same kit on turbomustangs.com earlier today. A guy was installing the same exact kit and writing a review on in soon. I just cant find the exact page, but I figured I'd at least put that out there.
Old Jan 22, 2007 | 01:56 AM
Ryaannn's Avatar
Ryaannn
Default RE: turbo
Ah, I found it.....
I am doing it... The official Ebay turbo build! DUW!
Old Jan 22, 2007 | 03:17 AM
EliteTuners's Avatar
EliteTuners
Default RE: turbo
Why twin? Ill sell a 88mm dual ball bearing 350$
Old Jan 22, 2007 | 08:05 PM
Cleeman99's Avatar
Cleeman99
Default RE: turbo
where do u live and it acully works new or used
Old Jan 22, 2007 | 09:55 PM
mcfomco's Avatar
mcfomco
Default RE: turbo
As of now the guy that doing the build up say's " the headers are the only thing that concerns him so far. The weld's are not the best in the world but could use minor touch up" As far as the turbo's he is taking them somewhere to get them inspected for quality. No report on that yet. I am going to follow this to seehowwell it goes.
ORIGINAL: luckythirteen13
