which cam ?
Old Jan 22, 2007 | 01:24 AM
hatchdemon89's Avatar
hatchdemon89
Default which cam ?
OK my friends got a 87 gt mustang everything has been converted to maf, he baught 302 crate thats carb now he's swappin it do fuel injected an hes needs to know what cam he should get for it since the cam that comes with a speed pro cam.for the carb setup but he decided to go fuel injected which cam should he get an upper an lower intake on a buget of 400 bucks?
Old Jan 22, 2007 | 02:46 PM
15austin's Avatar
15austin
Default RE: which cam ?
You can't buy a cam and a upper lower for $400.
Old Jan 22, 2007 | 02:49 PM
ROTTITANK's Avatar
ROTTITANK
U can used ....but I wounldnt do that.
Old Jan 22, 2007 | 02:55 PM
LCBlackDep183's Avatar
LCBlackDep183
why wouldent you buy a used upper and lower intake?...
Cams are cheap get a new one
Old Jan 22, 2007 | 03:22 PM
92GreyGT's Avatar
92GreyGT
Cams are fairly inexpensive, the stage one Trick Flow is a great cam for $150 and a used Cobra or Trick Flow can be had for $250.
Old Jan 22, 2007 | 03:36 PM
PX429's Avatar
PX429
call cam help.
Old Jan 22, 2007 | 03:43 PM
90Lxstanger's Avatar
90Lxstanger
Yeah +1 on the used intake, i'd see no problem there IMO, As for the cam, dont buy a used one unless its been regrounded
Old Jan 22, 2007 | 04:50 PM
w8less's Avatar
w8less
i gotta stock upper, lower and cam they can get ahaha
Old Jan 22, 2007 | 06:23 PM
TBird232ci's Avatar
TBird232ci
Why not use a used cam? Generally, a roller cam will not wear unless there is an oiling problem, or it has a rediculious amount of miles on it. A big thing in the Thunderbird/Cougar scene is taking the cam, heads, and intake from a 5.0 mustang, and using them to convert the SO 5.0 to an HO, and there hasnt been a single problem with the used cam.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
