Stock Shifter
RE: Stock Shifter
Why would people do that? Well any way ill prolly check later in the year being that is snowing But thanks for all of the help. If it turns out not to be a Pro 50 looks like ill change my sig. And Zach why did u choose 4.10's?
RE: Stock Shifter
i agree the stock shifter goes up... angles back, then up again, and is black... its a POS. just take off the boot, or even unhook it and look under it to see whats up w. the shifter... if it says hurst its not stock.
RE: Stock Shifter
Yea then i agree its not stock, atleast i know that, but does the lower boot just snap right off, or do u have to buy a new boot cause the rubber tore? Cause mine is kinda ripped any way
RE: Stock Shifter
ORIGINAL: 89 5.0 Mustang
RE: Stock Shifter
Hmm yea im not sure on what gears are in mine whether its stock or not, other then getting under the car and turning the wheels, there's no real way to tell? And dimebag thankyou for all the help ill check that out this summer, when i start taking it to shows.
RE: Stock Shifter
Well I have 2.73s in it right now and at 80mph I'm just hitting 2000rpm in 5th gear. Easy way to tell is look on the door and it will say axle code and have 2 letters under it. Someone can decode those 2 letters for you and tell you what you have.
