Carter or Holley?
RE: Carter or Holley?
ORIGINAL: ZachW04Stang
I would stick with a holley, they are pretty user friendly and everyone knows something about them. I've really never delt with a carter carb though.
and inmy opinion if you are serrious about the most power stick with a holley.. if you want a little better driveability with a little more torque down low cause of the spread borethen go with the carter/edlebrock. both are good carbs though... holley has had problems in the past with leaking butterfly shafts and power valves but it seems to be all taken care of now.
ORIGINAL: frdmstng1986GT
carters and edlebrock carbs are the same carb... if you look on the edlebrock carbs they actually say carter on them.
