Brake Booster and Master Cyclinder
RE: Brake Booster and Master Cyclinder
ORIGINAL: PRO50SC
Well, sounds like you're kinda clueless. That being said, you should really let a pro work on it so you don't kill yourself or someone else.
ORIGINAL: redmustang83596
Yeah its like the exact opposite, but doesnt the car mainly use front braking to stop the car? I cant get the brakes to work AT ALL, I had been slowing down with my gears and E-Brake and had to blow like 2 stoplights since it has happened, its dangerous and I just want to get this POS fixed.
If it was hard to push down that is a sign of the master cylinder going, i'd put my money on that since you siad it got harder and harder to push till it had nothing at all. They are cheap, i'd go ahead and do that first....
ORIGINAL: turbosha
is there fliud in the master cylinder? take the cap off and push the pedal down with it running , can you see a stream? bubbles? what have you tried? jack the front tire off the ground , give it a spin. do you feal any restriction ? does it keep going and going ? you should have some kind of drag from the calipers . o-yeah dont call your stang a pos, they dont like it.
I've been dickin with it for a while, I just dont have time anymore, im down at school and its at home, and I would like to bring it here to drive.. Im sure I can figure it out, just some suggestions would be nice
