New BOSS
RE: New BOSS
The new BOSS from what i read in motor tread is going to have fords create 5.0L Cammer. Its a DOHC FI engine. It will be like what the Mach 1 was for the last gen mustang. A filler between the Gt500 and mustangGT. also talk of a bullitt is in the works as well.
RE: New BOSS
it will probably be carbed most complete crate engines are, because people who are going to buy one tend to not have to worry about or care about emissions.Plus they dont want to alienate older crowd and older mustangs where they would make most there sales for crate engines.
RE: New BOSS
It wont be carbed because it will be a production vehicle. If Ford makes a carbed car you might as well consider the company bankrupty. It will be FI. Last production carbed mustang was in 84 or 85 (not sure so dont hold me to it). It will be more aimed at performance so the power to weight ratio should be good and im going to assume it will handle better than the regular mustang gt.
RE: New BOSS
ORIGINAL: speakerman86
I've been reading up on the new BOSS Mustang and Ford says it's got a "crate engine" What I'm wanting to know is if ford is going to be using dual 4bbl's or fuel injection.
RE: New BOSS
i have a article in 5.0 (on the cover is a sweet azz pic..if youve seen it) anyway itreads..built by GalpinAuto Sports andFord Racingits has..302 crate pushrod with Aluminum Z heads, Tremec TKO 600 tranny, 4.56 rear ax,8.8" rear end,Holley 780Carb,MSD Digital E-curve..
