Car died mid drive
#22
RE: Car died mid drive
probablyu the tfi module or it could be what happened to my car the cats would choke the motor when it go hot so i got an off road h pipe and some new o2 sensors
#24
replace the distributor with one from a junk yard 5.0 or get a new one , and TFI module on front.
after that take your car to Ford, just found out you have an OPEN recall on your vehicle[:'(]
Recalls Results
Parts and Service
My Vehicle
Accessories & Merchandise
Recall Information
Be advised that this system tracks safety and emission recalls for which vehicles are subject to repair in the United States. For more information on Ford Motor Company recalls or concerns you may be having with your vehicle, please contact your dealership directly.
Below you will find information regarding your affected vehicle.
Recalls Listed
1987 FORD MUSTANG ALL MODELS
95S28
IGNITION SWITCH REPLACEMENT
Recalls Results
Parts and Service
My Vehicle
Recall Information
Recalls Listed
95S28
#26
There definately needs to be some standardization of our terms here.....
Crank/no start means the starter moves the engine but it does not start
No crank means the starter motor doesn't even move.
If you are crank/no starting - use a little ether in the throttle body and try again. If you are testing spark with a wire tester and have no spark at all (it should be able to jump a half an inch) - the Ignition module is not getting a PIP signal from the Pickup Coil. This is in the distributor andI would recommend you just get a whole new distributor. This is fishing with dynamite so to speak, but if you have miles on your car its really worth the $. Not to mention it's a good idea if you are in the process of building a toy.
If it fires (starts or tries to start) on ether - you are getting spark but either have bad gas, a really bad temp input, or possibly a PCM that is not getting PIP and consequently not providing pulse to the injectors.
Perhaps too coincidental that this happened after a fillup, butperhaps not........
#27
Well It is finally fixed. It was the distributor. A small tiny piece of metal from inside the distributor itself from underneath the rotor. If I knew the technical name for it I would describe it but basically the rotor would turn but the metal disc underneath the rotor wasnt making contact. I called up ford, and a few of my fellow mechanic buds and none of them ever heard or seen that happen before, No wonder it escaped me .ThankfullyI had a spare distributor in the garage and it turned right over. Thanks for the advice guys, i probably would have wasted alot of time looking elsewhere.
P.S. Now that i got the new distributor in, what should I set my timing at? I have it at 12 degrees at the moment.
#29
I had the same problem, died while i was driving my anderson ford power pipe relocates the mass air in the fender well and the pipe rubbed the redwire on the MAFwhich has the same power supply asthe fuel pump. It ended up being a fuse link.
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
