steering rod hitting header
Old Jan 26, 2007 | 04:57 PM
85FOXGTkid's Avatar
85FOXGTkid
Default steering rod hitting header
i put out a post awhile ago about my steering rod hitting one of my headers....its still hitting and im jw if theres something i can do besides solid engine mounts...because im not gonna do that...thanks guys
Old Jan 26, 2007 | 04:59 PM
luckythirteen13's Avatar
luckythirteen13
Default RE: steering rod hitting header
what headers? stock steering shaft?
Old Jan 26, 2007 | 05:07 PM
85FOXGTkid's Avatar
85FOXGTkid
i have bbk 1 3/4' long tubes with stock steering rod
Old Jan 26, 2007 | 05:25 PM
93 LX FiveO's Avatar
93 LX FiveO
long tubes suck on a fox body
im sure u know this by now
Old Jul 11, 2007 | 08:32 PM
06Roush1's Avatar
06Roush1
What did you do about this problem... having the same problem with a new engine in a 92 vert LX 5.0. Just put in a 351 but the steering rod is rubbing a header. The guy who put it in grinded the rod but it is still a problem. Any suggestions?? Thanks for the help.
Old Jul 11, 2007 | 08:38 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Are the current mounts new? I shimmed my drivers side mount under the stud to frame part and solved the problem. I think I posted this in your last thread too.
Edit, just checked, it must have been someone elses. I've posted it so often, I forget where!
Old Jul 11, 2007 | 09:11 PM
creekrat's Avatar
creekrat
How bad is the rub? If it is not too bad, a few well placed swings with the ball peen hammer will give you a little bit. I'm not saying beat the crap out of it and smash the tube shot, but a little dimple will not affect flow , and may give you the clearance you need.
Old Jul 12, 2007 | 01:57 AM
SoDakStang's Avatar
SoDakStang
ORIGINAL: PRO50SC
I had the same problem. I swiched the motor mounts out with convertible mounts and it solved the problem
Old Jul 12, 2007 | 02:05 AM
Alero99's Avatar
Alero99
i have a 88 gt vert with equal length headers and it rubs for me... my mechanic had jsut put in a new rack and pinion steering for me... car drove beautiffully i guess after a day or two of driving the heat just undid what he did
Old Jul 12, 2007 | 06:57 AM
86HOGT's Avatar
86HOGT
Even my boss said his hit when he put in LTs. Mine didn't at all and I have BBK 1-3/4" LTs, Then again like stated above, I put in convertible engine mounts. He on the other hand put in a smaller u-joint in the shaft to get clearance.
