Drag car ?s
RE: Drag car ?s
You need an 8.8 out of a mustang to bolt up. A 650 carb is more than sufficient as long as its tuned properly
Have fun with swapping a 351 in a 4 cylinder car, keep in mind the brakes arnt sufficient enough for a 4 cylinder, the suspension is way soft, and youll have a lot of other odds and ends to change.
RE: Drag car ?s
I was thinking of leaving the breaks, I am gonna gut it all out, So it should be lighter? And will a c 6 from a truck work? Every one says go with the C4, but i can get a good c6 for free.. Or is the c6 in cars diffrent from the ones in the trucks? What about the shifting linkages? I wana keep a factory shifter in it, If i get a 4 banger mustang with a auto, Is it possible with the c6?
RE: Drag car ?s
I have a 1976 Mustang II coupe w/351C bored .030, 12.5 to 1 forged pistons, stock 4bbl clevland heads, edelbrock torker 351 manifold, 750cfm carb, .590/.590 comp cams cam shaft,MSDdistributor, MSD 6AL, 2 step module, hurst roll control, C4 4000 stall, dana 60 rear end w/ 5.38 gears, strange axles, spool, rear discbrake conversion, koni adjustable drag shocks, old school centerline 15x4's in front w 15x14's in rear, brand new mickey thompsonslicks,cage, tubbed, All windows Lexan, ran 7.01@98 in the 1/8th. Anyways If your looking for a 351 drag car I'm thinking of selling it soon I'm asking around $7000.
