CEL codes 67 and 44
RE: CEL codes 67 and 44
ORIGINAL: AdderMk2
code 67 is a problem with your air conditioning... your compressor has more than likely gone bad
This is my .02, take it or leave it. I guess it would help me out more if I didn't post anything at all since I will probably see some of the vehicles that have had multiple parts replaced come into where I work with the same concern still present. I just don't like seeing upset customers, this is good for no one.
ASE certified master technician, Ford certified senior master technician, 10+ years experience, Associates in auto service technology.
How sure are you that the PCM doesn't have a trace voltage on the compressor clutch control circuit? If it does (like it does on the fuel pump circuit), a fault will be noted with the circuit open. It knows that if that circuit is complete, all the voltage will drop along the internal resistor. If you unplug it, the voltage wont drop and it could ID a fault with it unplugged.
ORIGINAL: shaners90lxhatch
Wow, Adder. I am kinda surprised you didn't have anything to say to the new guy!
I am never one to just say "well, this is what its doing, so toss this in!" I like to test things and PROVE that they are bad.
but realistically... who uses a/c in a mustang?
