Injector Question
Old 01-28-2007, 12:43 PM
veto227
veto227's Avatar
Default Injector Question
This is my setup and need help with injector size before purchase. I've got a 91 stock bottom end, b-cam, SVO y-heads w/1.7 rockers, 73 mm C@L, 75 mm TB, Trick Flow Street intake, and a 100-125 NX shot of gas. Of course I already have the stall and rearend done. Last thing I need is the injectors. My question is should I go with 24 lbers or 30lb. Thanks.
veto227 is offline
Old 01-28-2007, 12:56 PM
kennebell92conv
kennebell92conv's Avatar
Default RE: Injector Question
i get 42s you will install more mods down the road
kennebell92conv is offline
Old 01-28-2007, 01:01 PM
veto227
veto227's Avatar
I have a set of 42's, I was just skeptical about them pushing too much fuel. I quess the dyno tune man can turn them down though. Another quick question, I have a Pro-M 80mm mass air made for an intercooler set-up. It is the blow through design. Would this work on my current set up?
veto227 is offline
FullAuto
FullAuto's Avatar
24s will be fine.
FullAuto is offline
Old 01-28-2007, 01:04 PM
badtzmaru
badtzmaru's Avatar
^^^ I think so too.
badtzmaru is offline
Old 01-28-2007, 01:24 PM
luckythirteen13
luckythirteen13's Avatar
run 24# injectors, 42# is rediculous for your car
luckythirteen13 is offline
Old 01-28-2007, 01:40 PM
rocketrotary
rocketrotary's Avatar
If you are planning on sticking with the current mods, go with 24s. If you are going to do some heavier mods in the near future, get the 30s
Vic
rocketrotary is offline
Old 01-28-2007, 05:32 PM
veto227
veto227's Avatar
Thanks for the input. Does anyone know about my mass air question?
veto227 is offline
Old 01-28-2007, 05:56 PM
7upedition
7upedition's Avatar
I dont see why 19's cant keep up with that setup... no power adder, but i assume your worried about being lean when nitrous is on, 42's are way more than you need even with the duty cycle tamed. 24's are readily available and will suit your needs.
7upedition is offline
Old 01-28-2007, 06:06 PM
craigwhite89gt
craigwhite89gt's Avatar
Id go with 30's but thats jus me...
craigwhite89gt is offline
Quick Reply: Injector Question
