I hate brakes
RE: I hate brakes
ORIGINAL: kl92gt
try cleaning the bleeder vlaves they might be clogged
RE: I hate brakes
ORIGINAL: HACKGT350
i was thinking the same thing the bleeder valves might be clogged i have done numarous brake jobs at work where the bleeders were clogged
ORIGINAL: kl92gt
RE: I hate brakes
ORIGINAL: craigwhite89gt
Ok well here is the story. I got Brothers perf. stage 4 brake kit which means 73 MM Calipers, Pads, Slotted rotors, and steel braided lines. I know i should upgrade my Master Cyl. BUT im not goin to yet. Cuz i should still be able to stop for now. OK my problem is after numerous times of bleedin the brakes properly starting at the right back I do not have pedalpressure. One thing ive noticed. When we do the right rear i get some pedal pressure by pumping them then like 2 out of 5 times when we crack open the bleeder the pedal goes to the floor like it should while the other times the pedal stays hard and barley anything comes out. Im at a loss.. Im begining to belive my master cyl went bad ?? Any input would be great
RE: I hate brakes
Started car.... and doesnt help... This is one of those moments where you ask yourself...why me...
RE: I hate brakes
(((( STORY)))
A man called me I cannot get my brakes to work .They need bleed and I have dont it 5 times>
I towed the car to the shop ($150) put it on the hoist and >>> found he he pumped up cracked bleader andlet off the pedal forgot to tighten up the bleader first <<<$175 in my pocket.
RE: I hate brakes
OK here is what we have decided is wrong. Master Cyl. We belive it is this becuase like i said we could get like 2 out of 5 times fluid to come out the back and the pedal go to the floor. So we pumped up the brakes and cracked open the fitting for rear brakes directly off of the master cyl. And jus like when we were bleeding them. Like 2 out of 5 times fluid would spray out. The other times the pedal would stay where it was and we might get a drip out of it. I belive im going to get a 93 Cobra MC
