which one is better?
Old Jan 29, 2007 | 01:59 AM
ucjattriskey510's Avatar
ucjattriskey510
Default which one is better?
Ford 5.0L/5.8L Performer Aluminum Cylinder Head [*]170cc Intake Ports[*]60cc Combustion Chambers[*]2.020' Int/1.600' Exh Valves[*]1.460' Valve Springs, .575' Max Lift
OR
Ford 5.0L/5.8L Performer Aluminum Cylinder Head [*]170cc Intake Ports[*]60cc Combustion Chambers[*]1.900' Int/1.600' Exh Valves[*]1.460' Valve Springs, .575' Max Lift
is $589 price of one head or 1 set of 2?
Old Jan 29, 2007 | 02:01 AM
dimebag's Avatar
dimebag
Default RE: which one is better?
i think the 1st is better... and thats the price for one, not the set
Old Jan 29, 2007 | 02:04 AM
FullAuto's Avatar
FullAuto
I'm going to say #2 is better just because dimebag said #1 was better and I want confuse you more.
ucjattriskey510
with the 1st head listed above, if i put an intake and new camshaft will i reach 300rwhp?
Old Jan 29, 2007 | 02:05 AM
dman302's Avatar
dman302
Neither...Eddy TW or AFR can be had for that price range all of which will outflow and out power the above heads. 302,306 motors benefit more from the smaller valve heads not to mention larger valve heads most often require notched pistons.
FullAuto's Avatar
FullAuto
ORIGINAL: ucjattriskey510
Highly doubtful.
90mustang5.8's Avatar
90mustang5.8
I ♥ Acer
ORIGINAL: FullAuto
haha......#1 is better
Old Jan 29, 2007 | 02:09 AM
dman302's Avatar
dman302
300 to the wheels will take more than ford alum heads and alpha cam..you'll need a much better head matched with a well chosed OTS cam or custom and a quality intake...oh and an excellent tune. 300 plus to the wheels is harder than most people realize with an n/a mild compression 302/306...it can be done but it's not just bolt and go.
Old Jan 29, 2007 | 02:13 AM
ucjattriskey510
if i went for trickflow twisted wedge do i need special headers for that cause right now i got a bbk unequal lenght shorty headers.
Old Jan 29, 2007 | 02:19 AM
dman302's Avatar
dman302
???? No only the GT40P heads require a 'special' style header. You should look at the tw kits, IMO an excellent kit that untuned reliably puts down great numbers. 300 is still a stretch but as I've seen you really cant feel the difference between 280's and 300's on the street, the kit is complete and cost effective IMO.
