Please tell me what you think is wrong with this trans. I need help
RE: Please tell me what you think is wrong with this trans. I need help
I cant get to the car until Sunday seeing as I have family coming into town. I wanted to know, if it is just fluid, will it run after a change it?
there is no way it's the throwour bearing, even if it did lock up it wouldn't prevent the the tranny from moving unless it welded itself to the pressure plate and the brearing retainer (shaft it slides on) and that is damn near physicaly impossable....
there is no doubt that it's internal but i have no idea what, spun a bearing maybe, fused a bearing to a bearing race, if it was a grenaded gear you would now, i t would make all kinds of noise
No.... if it ran out of fluid, its done.
ORIGINAL: aftlcc
well i didnt know auto;s had throwout bearings
but what happened is your front pump went south, failing to lubricate, and the seizure came from expansion from the heat caused to that effect, also total coverter failure could of sent paticles into the valve body.
when my AODE in another vehicle did this on the highway, the rear lock up and sent me spinning all over[:'(]
ummm??? who said it was an auto???? an auto wouldn't "wiggle" in neutral even in working order... and the sig. said he's look for an aod not that he has one... correct me if i'm wrong but i believe that its a t-5
ORIGINAL: aode06
What makes you think it is an auto?
ORIGINAL: aode06
