timing cover
Old Jan 30, 2007 | 08:10 PM
turbosha's Avatar
turbosha
Default RE: timing cover
say no to gaskets, even diff cover. make sure everything is CLEAN scrap and sand all old gaskets completely off
Old Jan 30, 2007 | 08:12 PM
mattdel's Avatar
mattdel
ORIGINAL: turbosha
i like using an old balencer honed out so it slides on the crank, you can getthe coveroff alittle bit if your not carfull.
[sm=dontgetit.gif]
Old Jan 30, 2007 | 08:13 PM
mattdel's Avatar
mattdel
wow do you really sand the block? they make stuff to clean gaskets with ya know, no need to damage the block.
turbosha's Avatar
turbosha
if you install the balencer with the timing cover at the same time , then tighten all your bolts it will line up perfectly, no front seal leak.
Old Jan 30, 2007 | 08:16 PM
mattdel's Avatar
mattdel
ORIGINAL: turbosha
thats actually a good idea... too bad i just did a balancer and didn't save it
Old Jan 30, 2007 | 08:17 PM
turbosha's Avatar
turbosha
Old Jan 30, 2007 | 08:18 PM
thedude's Avatar
thedude
Not sure I follow. The balancer and the cover are two separate pieces right?
Old Jan 30, 2007 | 08:20 PM
turbosha's Avatar
turbosha
yup, are sure you should be doing this ?
Old Jan 30, 2007 | 08:22 PM
thedude's Avatar
thedude
no
Old Jan 30, 2007 | 08:24 PM
thedude's Avatar
thedude
Im confident I can do it. I just need some instructions.
