What needs done to make an engine a stroker?
RE: What needs done to make an engine a stroker?
ORIGINAL: FuzzyDiceRule
machining only needs to be done with boreing, only if you try to stroke a 302 to like a 358 or something, you may need to clearance the block.
ORIGINAL: Edge_of_Sanity
actually even for a 331 stroker you have to notch the block.
Gsp, I have this book called Mustangs on a budget. They build a 331 and mention it needs to be notched. I do think it depends on what rods your using, and im sure it wouldnt take much grinding. But in most cases Id say yeah it needs some machining.
Making a 351 a 408 is the same deal.
ShaneB26154
35
03-04-2021 04:05 AM
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
YoungStangsMan
09-05-2015 07:01 PM
