pics after completion
car looks sick man, mine is identical with 4lug 03 cobras in chrome and i have diff size tires and frpp c springs. which way of doing the 5 lug swap did you use, 50 resto kit, junkyard? also did you have to remove the quad shocks for the 275/40's on the rear? i want to do the same thing with the 5 lug swap and cobras.thanks man, and the car is BAD!
Thanks for all the good replies guys. Yes I did paint the car myself, my father in law is a body man, and I sprayed it. This is my fifth car I painted, not to hard its all the prep work that will make the car look good or bad. *** do not get the 5.0 resto kit if you plan on using 17x9 oem cobra rims THEY WILL NOT FIT UP FRONT. I made that mistake luckily my friend had the sn95 calipers and rotors, so I traded him for the 5 lug rotors I got from 5.o resto. Yes the quad shocks had to be removed for my tires. My front tires rub against the A arm if I make a tight u turn. Does anyone know if you can buy A Arms that are shorter in width than stock???
jwog666
Dec 27, 2021 08:09 PM
Lethaldosage423
Oct 19, 2015 12:12 AM
