mass air vs. speed density
ORIGINAL: africkanV6
is that parts and labor or jus parts? how long would it take to complete the process?
yeap. how much more power would a 306 make over a 302? worth the money?
If you try and keep the 302, it will probably cost you at least a $1000 more for a new block.
Boring the cylinders last I checked was about $20 per cylinder. It would cost about $300 to make you block fresh(bored, decked, dipped, ect) around $450 for a basic rebuild kit (pistons, rings, seals, bearings, oil pump, timing set,ect) and another $100 to $150 to get your heads redone(valves, seals, shim springs, ect) I would guess somewhere around $250 to $500 to assemble(no idea, just a guess)
I'm not saying all that is fact, just a round about of the whole thing and I probable miss some stuff too. Also, it isn't a gaurantee that you will ever have to touch your motor either...140,000 is still low as far a 5.0's go. Good luck.
to do the maf conversion jegs has a harness taht jsut splices into the original seed density wires and then i believe all you have to do is replace the computer with a maf computer
speed density isnt as bad as everyone wants to say it is... yes it takes a lil more effort to get **** to do wut u want it to do, but u can do the same damn things(minus some, well most, cams)
ORIGINAL: mopman93
http://www.stangnet.com/tech/maf/massairconversion.html
Sep 8, 2015 11:50 AM
