couple Qs about the 5 lug swap
alrighty, so i've had a bunch of the parts here waiting for over a year and i'm about to start working on this. I have the front and rear calipers/rotors and brackets from a 96, but i'm still lacking the axles/spindles/MC/BB/PV/all the lines ...hardware etc.
now the question is this, would it be a bad idea to get ranger axles and drums in the rear instead? ...someone correct me if i'm wrong, but i presume that the rotors would add more rotational weight than drums? and i also assume that the swap would be easier/less expensive because i don't think i'd need the MC/BB/PV and the lines to do this... i'm just worried that it could be a bad idea to pair the sn-95 front brakes while staying with drums in the rear, could this cause it to be unstable or something?
RE: couple Qs about the 5 lug swap
I've heard of this kind of swap before. If you dont mind me asking, what year Ranger do you take the axles out of? I would love to do a cheap 5 lug swap.. Swapping axles is cake, but which 5 lug front rotors/spindles bolt right up to the stock calipers?
I dont see why you wouldnt be fine I mean your not really changing that much and only going to a little bit bigger front caliper. BTW whats going on with those pony rims? haha I might have a home for them!!
How about the fronts? I have everything but I keep hearing that I need a specialline for the passenger side.
im running 95 brakes up front and drums out back, and I havent had one problem, as for the brake line you can buy an adpater or MM sells SS lines that dont need adapters
ORIGINAL: primetime5.0
