help
Old Feb 3, 2007 | 01:18 PM
2 kwik's Avatar
2 kwik
I ♥ Acer
Default RE: help
change the filter more often , not the oil....
Old Feb 3, 2007 | 01:24 PM
5.0eric's Avatar
5.0eric
Default RE: help
ok now about that sceen where is it? and thanks for your help
ORIGINAL: 2 kwik
Old Feb 3, 2007 | 01:33 PM
2 kwik's Avatar
2 kwik
I ♥ Acer
Default RE: help
it's in the hole where you PCV is located..it's not easy to pull out but has been known to clog up
Old Feb 3, 2007 | 01:48 PM
5.0eric's Avatar
5.0eric
Default RE: help
ok iam going to give it a shot thanks for the help
Old Feb 5, 2007 | 12:11 AM
5.0eric's Avatar
5.0eric
Default RE: help
anyone else have any more advice
Old Feb 7, 2007 | 03:55 PM
5.0eric's Avatar
5.0eric
Default RE: help
no smoke/blowby out the filler neck so what can it be
ORIGINAL: PRO50SC
How many miles on the engine? If you pull the oil cap on the engine while it's running do you get a lot of smoke/blow by out of the filler neck?
Old Feb 7, 2007 | 04:09 PM
scottrich411's Avatar
scottrich411
Default RE: help
if you had fuel in your oil it would be really thin, watery looking, but black, and smell like gas. oil gets darker pretty quickly after its changed....if you're real worried about it, send some out to get analyzed, they might be able to tell you something. I've heard really good things aboutthat seafoam stuff, like pour some in with the oil a few hundred miles before you change it, and it cleans up the engines internals pretty well, and oil stays cleaner longer. i dont know for sure, but i hear good things.
Old Feb 7, 2007 | 04:17 PM
5.0eric's Avatar
5.0eric
Default RE: help
ill have to give it a shot but what worries me is the oil am burning
ORIGINAL: scottrich411
Old Feb 7, 2007 | 04:34 PM
5.0eric's Avatar
5.0eric
Default RE: help
bump
Old Feb 7, 2007 | 10:17 PM
5.0eric's Avatar
5.0eric
Default RE: help
bump
