help
Old Feb 3, 2007 | 02:42 AM
5.0eric's Avatar
5.0eric
Default help
ok well my stang is burning oil bad but the olny time i see smoke is when i floor it also my oil turn black fast after a few days of doing the oil chang it turns black so i know iam getting some gas in there how can i fix this ??? or do i need to rebuild the engine
Old Feb 3, 2007 | 02:50 AM
90Lxstanger's Avatar
90Lxstanger
Default RE: help
Well really that doesnt mean your gettin gas in there. If you are gettin gas in the oil, itll smell like raw gas, and really, really bad, plus it will start to overfill the oil too ex. my bros pressure regulator wne t out, his oil was overfilled like 1.5 qts. It sounds like kinda the same problem i have, i burn about 1 qt a week, and now that im driving 100 miles a day, i burnt 3/4 a quart today. it coulfd also be a PCV probem, which that is what im trying the figure out right now
Old Feb 3, 2007 | 02:55 AM
5.0eric's Avatar
5.0eric
Default RE: help
yea iam also burning like a qt a week but i changed my pcv not to long ago so what can it be any idea on y my oil is turning black
Old Feb 3, 2007 | 03:05 AM
5.0eric's Avatar
5.0eric
Default RE: help
someone help me
Old Feb 3, 2007 | 03:20 AM
90Lxstanger
Default RE: help
sorry im taking a while... what thickness are you running? im runinig 5w-30, bad mistake , dont run that i think im goin with 10-40 next which will be soon, and how many miles are you running in a week also?
Old Feb 3, 2007 | 03:29 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: help
How many miles on the engine? If you pull the oil cap on the engine while it's running do you get a lot of smoke/blow by out of the filler neck?
Old Feb 3, 2007 | 12:37 PM
5.0eric's Avatar
5.0eric
Default RE: help
i haven't done this but i will as soon as i can the motor as 95K iam using 10w-30 oil iam thinking of using 10w-40 on my next chang right now i dont drive the car cuz its winter in the spring i drive it like 90miles a week and i want to fixs this befor spring comes so any advice is welcome
ORIGINAL: PRO50SC
Old Feb 3, 2007 | 12:57 PM
5.0eric's Avatar
5.0eric
Default RE: help
bump
Old Feb 3, 2007 | 01:09 PM
2 kwik's Avatar
2 kwik
I ♥ Acer
Default RE: help
did you clean or replace the PCV screen? going to 10w 40 isn't going to help....as for your oil turning black fast, try replacing the oil filter @ about 500 miles into the new oil it will clean up.. it may take a few for the engine to :clean up:
Old Feb 3, 2007 | 01:17 PM
5.0eric's Avatar
5.0eric
Default RE: help
i changed the pcv its self where is the screen and u think if i changed my oil more often it well clean up ?
ORIGINAL: 2 kwik
