Traction Lock clutch kit question
i am about to do a 5 lug swap and thought i might as well replace the old trac lock clutches so i dont have the one wheel peel anymore. does anyone have a write up or any info on exactly how to do this? and in this kit.. http://www.latemodelrestoration.com/...1&comp=LRSis that one bottle of friction modifyer all i need for fluid in the rear end?
ORIGINAL: 2 kwik
add the modifier after the first qt.
If it comes with instructions it will likely say to soak or at least coat the friction disks with the modifier fluid. If you choose the right container, I'd just add it to a half a qt as mentioned above and put it in there that way.
Its easy. There are tough parts, it requires a little finess especially when it comes time to getting that spring back in there. Everyone has their own method. Best advice - Get a service procedure to follow. Ideally, someone who has done it before. If you have never picked up a carrier before - Enjoy! Its a lot harder to hold on to when its wet. You'll see what I mean.
I just replaced mine, use the shim thats in their dont forget it or you'll regret it. I didn't soak mine we forgot and now they chatter, it takes forever for the fluid to work back in 'em so soak them in the modifier first. Also, dont break that little 8mm bolt off or you're going to have a helluva time. Be very careful.
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
Sep 1, 2015 08:16 PM
